FIFA 14
Status
Not open for further replies.
Just lost to Shane Long outjumping Chiellini from a corner. This game is laughably poor, I cannot manage more than 1-2 games an evening. It's utter, utter garbage.
I know putting Ibra at CDM is probably mad, but I think it might work o_O
As much as it IS insanity and I said as much to you earlier, I remember the team I had last year now, 433 with Ibra LCM, TOTS RIbery LW< ROnaldo ST and Robben on the right, TOTS Gonalons & TOTS Vidal accompanying Ibra, worked quite well!
BUT NOT A MONTH IN!! IT SHOULD BE MEEEE /HISSYFIT!! :D
Yesterday I won a game with Neymar out jumping Felliani, Kaboul and cech to win a header a score.
I did the shh celebration into the calm down celebration afterwards and he rage quit. :p
I had the same only I was on the end of it.
Wait for it.....NASRI who is just over 5'7" outjumped Kompany, Chiellini and Handanovich to score in the 90th minute and he ran down the pitch doing the DJ celebration.
i really dont understand the game mechanics for headers.... it seems that some people are experts and can win most headers.......... seems very lucky and random if i knock one in.
Ive been trying hard to improve defending against crosses/corners - I just manual switch just before the ball gets to the player, stand off a bit and go in rather than a standing jump, seems to help.
i usually (in corners) select a player away from action - let it autoswitch and press shoot - against most players its not too bad - but some people seems to win every header..........
In normal play sometimes it seems both in attack and defence - the movement of your player is automatic and u will either be in a good position to win the header or not.
I just find it the most frustrating way of conceding, similar to crosses, because you have pretty much no control on the outcome. You can jostle a bit, which does not make much difference anyway, but if the game decides that you're going to lose the header then you just lose a goal. It's as simple, and as frustrating, as that.
trying to create a team with 4-3-2-1 formation, IF hulk RF, Neymar/D. Costa ST, Ronaldo LF.
i can get full chem, its just i have to have casemiro at CM ( a 77 rated) :/ I could try him i suppose but i can get 9chem or higher on all players with ramires at CM
Nothing against you personally but what enjoyment do you get by crossing at every opportunity?
Like I say nothing against you genuinely curious :o
Don't get me wrong, I like dribbling and passing through midfield with my 3 CM's (all 80+ dribbling). But when your opponent has got defense on lock-down, the only thing to do is abuse the wings and make use of the game's overpowered headers :p
Status
