.Got 2653 Stock cooler still can't get past the 1100mhz barrier without flickering as i use the mouse wheel once hitting apply. I know an increase of less than 100 or so may seem trivial to update, but I want a stock 290 above a titan
(assuming Gibbo's score was under water or something, or holy mother I want that one
Well, I can't say I am not annoyed, but I think this is the limit of my 290. At least I beat the lowest Titan.Got 2653 Stock cooler still can't get past the 1100mhz barrier without flickering as i use the mouse wheel once hitting apply. I know an increase of less than 100 or so may seem trivial to update, but I want a stock 290 above a titan
Core: 1100
Memory: 1447
Can someone clarify: Does CCC keep stock voltages? Or is that what the power consumption slider is changing?
Take a different tone with me and i might change it.
Failing that, keep your nose out of where it does not belong.
If Kaap wants me to change it he can ask me.
Or you could just correct your error. Easy.
Nice attitude though.
Do I report my clocks as they show in GPU-Z or what they appear to max at on the afterburner graph?
