Catzilla 1.0 Benchmark Scores
13 Jan 2004
Reference 780Ti
1094 Core / 3499 Mem (Stock with 106% Power Target basically):
1234 Core / 3649 Mem (OC with 106% power Target)
How does one do 1080p without upgrading software? Custom 1080p Preset and leave what it sets?
13 Jan 2004
Unfortunately you can only run @576p and 720p unless you upgrade the software.
I have put your CPU down as a 2600k @4.4 I got this from another thread.
And congrats on a very nice score.:)
Ah, that's a shame. Rarely see > 50-60% GPU usage in 576p :D
2600k @ 4.4 indeed. Used to run at 4.6 but BF4 does not like it. Catzilla really likes CPU speed as well, good to see a combined benching suite.
Caporegime
20 May 2007
Surrey
What crashes were you getting in BF4 with the cpu at 4.6? BSOD's?
19 Jun 2004
n/east-the toon
Hi kaaps, l take it my results don't make sense, yes l'm running sli and its set up correctly in Nvidia Control Panel > Configure Sli is set to Maximise 3D performance=Ticked + PhysX setting=CPU.
Both Gpu'S are working with Boost, at stock both idle at 915mhz when Max Boost comes in GPU 1=1058MHz / GPU 2=1084MHz. The only thing l can think of when looking at Catzilla Benchmark test again. l did not set my resolution to 1024x576 for the 576p run and 1280x720 for 720p, could this be the problem with my results?.
So re-ran the two benchmarks again with my i7 930:4.030GHz not 4.217GHz and GPU's at stock, Catzilla is showing SLI -
Test 1 - 1024x576[576p] Score=21074 / Test 2 - 1280x720[720p]=19072.
According to Openhardware Monitor boost is working during the test's Max Boost > GPU 1=1058MHz / GPU 2=1084MHz.
Do these results make better sense.
Cheers,
Oldphart.:confused: LOL
Man of Honour
OP
21 May 2012
Dalek flagship
Cheers,
Your results were fine, with Catzilla you can get some really bad CPU bottlenecks so to get the same score @576p and 720p is possible and nothing to worry about.:)
I just needed to know that you were running the GTX 670s in SLI.:)
And on the scoreboard.:)
