Visual Studio 2013 goes RTM
They still haven't fixed the disaster with bookmarks which last worked in 2008. Since then they are tied to line numbers (even if you aren't displaying them) rather than lines of code so add or delete code above a bookmark and it no longer stays whee it was set.
Not sure if anyone will need this but if anyone has VS2012 and no MSDN, MS have an upgrade to VS2013 on their store for £100.
Remarkably annoying!
It makes them a complete waste of time. The only alternative is to use disabled breakpoints, but that isn't as good as bookmarks used to be.
I expect it is but I don't do any java. Try right clicking on a lone of code and see if you get a bookmark option in the CMS three lines from the bottom.....
