CPU 4/8 Pin connector
7 Feb 2011
Need some help please :confused:
Just connecting up my PSE
http://www.overclockers.co.uk/showproduct.php?prodid=CA-075-BQ
to my motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=MB-502-AS
There's one branch of power labelled CPU and it is 2 x 4 pins - sounds fine as the socket on the board is 8 pin.
HOWEVER, the pin layout only matches for one of the 2 units.
They both need to be
Square / Curve
Curve / Square
But the second has 4 curved connectors?
It fits in the socket fine & looks to be wired the same (2 x yellow, 2 x black), so I guess they are actually the same, just different socket?
Am I ok to leave both in place?
TIA
Yes just put them together so as to make 1 x 8 pin and they will go in. They only go in one way anyway. I think they usually have a piece of plastic on the back of each connector which makes them interlock with each other.
that's good to hear.
The surprise was that the 2 4 pin connectors marked "CPU" are different, which they are not supposed to be according to my motherboard connector!
