13 Nov 2013 at 20:02 #181 Ace Modder Ace Modder Soldato OP Joined 8 Sep 2003 Posts 23,180 Location Was 150 yds from OCUK - now 0.5 mile; they moved Well latest update
13 Nov 2013 at 20:10 #182 T345 T345 Soldato Joined 14 Oct 2011 Posts 5,740 Location Kent Them blocks are very nice + I love the fans
14 Nov 2013 at 12:45 #183 Ace Modder Ace Modder Soldato OP Joined 8 Sep 2003 Posts 23,180 Location Was 150 yds from OCUK - now 0.5 mile; they moved change on plan I don't think the orange/gold fittings matched the rest of the orange in my build. so now I have......
14 Nov 2013 at 14:19 #184 Ace Modder Ace Modder Soldato OP Joined 8 Sep 2003 Posts 23,180 Location Was 150 yds from OCUK - now 0.5 mile; they moved
14 Nov 2013 at 19:06 #185 systemerror systemerror Associate Joined 8 Jan 2012 Posts 668 Much better with the black monsoon fittings
14 Nov 2013 at 19:42 #186 Ace Modder Ace Modder Soldato OP Joined 8 Sep 2003 Posts 23,180 Location Was 150 yds from OCUK - now 0.5 mile; they moved systemerror said: Much better with the black monsoon fittings Click to expand... Yes, hence the reason I swapped my out at OcUK today. Best thing I've done.
16 Nov 2013 at 00:25 #187 Ace Modder Ace Modder Soldato OP Joined 8 Sep 2003 Posts 23,180 Location Was 150 yds from OCUK - now 0.5 mile; they moved Well did some work earlier. But run I'm need some 90 degree fittings.... tomorrow another trip to OcUK
16 Nov 2013 at 00:33 #188 Ace Modder Ace Modder Soldato OP Joined 8 Sep 2003 Posts 23,180 Location Was 150 yds from OCUK - now 0.5 mile; they moved no idea how im going to fill it with fluid now as the fill port on the res is not accessable. Maybe unscrew the res and angle the top of it forwards. Last edited: 16 Nov 2013
16 Nov 2013 at 11:22 #189 clone clone Soldato Joined 11 Jul 2003 Posts 7,952 Location Telford//west mids Put a 90 on the top of the res with a fitting and run a hose to the top and use a funnel.
16 Nov 2013 at 13:42 #190 klaxhu klaxhu Associate Joined 28 Nov 2012 Posts 274 Location Zurich, Switzerland you have plenty of space to fill it up with one of those squeeze bottles that have a straw
16 Nov 2013 at 16:11 #191 Ace Modder Ace Modder Soldato OP Joined 8 Sep 2003 Posts 23,180 Location Was 150 yds from OCUK - now 0.5 mile; they moved I just unscrewed the res from the plate and tilted it forwards... easy peasy tbh. Many improvements make to the tube layout Which involved 2 seperate trips to OcUK for more fittings All being leak tested now
16 Nov 2013 at 16:14 #192 Mole. Mole. Associate Joined 10 Jun 2013 Posts 252 Location Ipswich I love the look of the CPU block with those two 90 degree fittings, Amazing!
16 Nov 2013 at 16:20 #193 Ace Modder Ace Modder Soldato OP Joined 8 Sep 2003 Posts 23,180 Location Was 150 yds from OCUK - now 0.5 mile; they moved yeah they go straight once the res is back mounted up on the tray, not lowered resting on the floor like it is at the moment.
16 Nov 2013 at 16:50 #194 CharlieRich CharlieRich Associate Joined 3 Nov 2013 Posts 320 Location Surrey Mother of God... Computer porn at its finest!
16 Nov 2013 at 16:58 #195 clone clone Soldato Joined 11 Jul 2003 Posts 7,952 Location Telford//west mids Aye really like it good work Ace
16 Nov 2013 at 17:53 #196 Ace Modder Ace Modder Soldato OP Joined 8 Sep 2003 Posts 23,180 Location Was 150 yds from OCUK - now 0.5 mile; they moved Getting the air out of the loop and into the top of the res is proving to be "fun"
16 Nov 2013 at 18:01 #197 Ace Modder Ace Modder Soldato OP Joined 8 Sep 2003 Posts 23,180 Location Was 150 yds from OCUK - now 0.5 mile; they moved here you go
16 Nov 2013 at 19:07 #198 rjk rjk Caporegime Joined 8 Aug 2007 Posts 25,380 Where is the flow going? To the CPU block first? Because if its going to the CPU block first. They its going into the outlet of the block and won't work properly.
17 Nov 2013 at 00:25 #199 Ace Modder Ace Modder Soldato OP Joined 8 Sep 2003 Posts 23,180 Location Was 150 yds from OCUK - now 0.5 mile; they moved Well Rich my temps seem to confirm you are right My GPU's are not hitting 40 degrees - hovering between 37-39 degrees in 20mins of furmark However prime95 is causing my CPU to high 70 degrees and I havent even clocked it yet. Looks like I need to drain and flip my block round (hope I dont need to cut new tubing for it) but I think I will. Anyway a few pics here Also I was 1 PCI-E orange braided cable short today, so need to get one Monday also.
17 Nov 2013 at 00:29 #200 pgi947 pgi947 Soldato Joined 25 Jun 2011 Posts 16,797 Location Aberdeen Looks cracking mate You may get away with rotating the block 180 degrees of you want to keep it as is
