Caporegime
- 18 Sep 2009
- Dormanstown.
My Haswell runs 4.75GHZ, that's a high OC, no delid.
The budget i just had which was £850-£900 i could have gone intel but after having an 2500k and i7 3820 and reading so much about haswell and ivy needing delids if you want to clock high etc i decided to try FX out.
And im glad i did
Perhaps people should try more than one guide when OC'ing. Haswell OC is more about knowing how it works, and adding other stuff than just Vcore.
But this is offtopic.
Yes but your an exception
Everything you have seems to be better than anyone else's
Not including the R 290
Thats a golden chip. Can you run that stable in BF4?
GTA 4, ARMA 2, Crysis 1, Oblivion, Skyrim, Supreme commander.... There's loads...
The 4670k would easily manage a rock solid 60fps given enough GPU power, the 6300 would manage them at 60fps but not a rock solid 60fps with no dips in the frame rate.
My 4770K refuses to be stable above 4.5GHz no matter what I do. Temps are fine, 60-70C under load. It's been the same with others, though the one at 4.3GHz needed 1.35v for that, which is pretty high.
I'll let you into a secret i use 1.48v to hit 4.6Ghz. Temp's hit 100oC sometimes I hit 103oC and it throttles. (briefly and after hours of play)
If you want 4.5Ghz I suggest with those low tempatures you should try 1.46v and work the voltage back. As long as your temps are below 100oc under load it wont throttle. If you try this let me know if it works.
In arma 2 a 2500k will only get around 45 fps when things are happening. The game runs so poorly on Intel you can't notice the fx is marginally slower...
Seems hot. I sit around 40c while gaming with 600rpm fans
Ivy takes higher voltages, Haswell would need very high end cooling for 1.46v I think. The recommendation is usually 1.35v max for water cooling.
