New rig killing PSU's?
20 Nov 2010
Hello
About nine months ago I built a new rig and used a “1050W Seasonic X-1050 Modular” as my power supply. After a few months of use I started having issues with my system in that it would not turn on consistently when I was pressing the power button, I RMA’d the power supply and received a replacement. The replacement power supply until today had been great.
I am now starting to have the same issues with the replacement power supply, the power button will perhaps work 5% of the time. I believe the PSU is once again failing, my question would be am I just really unlucky or is it more likely that there is something wrong with my build that is eventually killing PSU’s?
Thank you for any help you may be able to give.
Rick
Sorry the following are no longer on the site:
Gigabyte Z77X-UP5 TH Intel Z77 (Socket 1155) DDR3 Motherboard
Patriot Viper "Black Mamba" Generation 3 16GB (2x8GB) DDR3 PC3-12800C9 1600MHz Dual Channel kit (PV316G160C9K) x2
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX) HDD x2
YOUR BASKET
1 x EVGA GeForce GTX 670 Superclock w/Backplate 4096MB GDDR5 PCI-Express Graphics Card £359.99
1 x Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £251.99
1 x Samsung 256GB SSD 840 PRO SATA 6Gb/s Basic - (MZ-7PD256BW) £193.99
1 x Seasonic X-Series 1050w '80 Plus Gold' Modular Power Supply £179.99
1 x Corsair Graphite 600T Midi Tower Case - Silver (CC-9011020-WW) £149.99
1 x Asus Xonar Essence STX Sound Card £134.99
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler (CW-9060009-WW) £99.95
1 x Liteon DH-4O3S-04-B 4x BD-ROM (Black) - OEM £34.99
Total : £1,418.47 (includes shipping : £10.50).
May i ask what made you buy an expensive 1050W PSU for that setup? Seasonic are usually excellent too!... Maybe it's fed up with being under utilised :p.
Originally I had planned on going SLI but when one of the graphics cards failed I just never replaced it. Apart from that I’d rather have a PSU that is underutilised and have loads of room for expansion.
I would look at something along these lines. 2 faulty PSUs - odds are pretty astronomical
Normally I’d completely agree that it’s the button on the case and not the PSU, that said if it’s the button on the case surely a replacement PSU wouldn’t have resolved the issue?
even if going sli you don't need 1kw+, the 750w or 850w one would have been better. could have either saved the money or put it towards improving the spec elsewhere.
Little bit of a further update, when I press the power button there is around a 10 second delay before fans and such start. I'll have a go a resetting the cmos.
Thanks
Rick
I have my evga psu for over a year an works perfect from day 1.
And as for hdd's I still use a 500gb seagate 2.5" hdd from my old laptop. It's 4 years old and still works very well. I wouldn't really blame seasonic to much, maybe you were just unlucky.
I was unlucky with my corsair psu's, had 2 with faulty fans and it completely put me off from buying anything by corsair for a few months. Glad Im over it, bought a Corsair 540 last week and I love it :-)
Im sure you just had bad luck like me and you will get a psu that suits your needs and will last for years, dont worry.
