- 6 Jul 2009
Any truth in that the brace postion is really to keep your teeth and bits together so i.d is is easier afterwards ?
Also there is a 75% chance that they will be flying over water at the time so most people will either drown or die of exposure when they land.
I think this % is reduced if you fly from say Luton to Glasgow.![]()
Not 100% sure i agree with that, a smoke hood in most cases would be a better bet.
On a recent flight home the panel above my head was held on with gaffer tape.
On the way back from Abu Dhabi with Qatar air we were on a plane that still had ash trays in the seats, it must have been from the 80s or 70s. It looked realy old and was very noisy.
I am now considering to refuse flying on old planes and ask to be moved to a later flight and see if they can do it.
Old plane has flown 100,000 hours without crashing
New plane has flown 1,000 hours without crashing
Assume 0.5% chance of crashing for the new plane and 1% for the old plane.
Statistically, even with doubling the risk the old plane is still much more likely to get you to the end of your 4 hour flight alive...
It's a quick glance over the plane to make sure the landing gear is ok, no fluid leaks and all panels are still attached etc, it doesn't take long for the ground crew to do.
What about on Easyjet/Ryan air where its a 30 minute turn around?
easyjet and Ryanair are "shorthaul operators so any particuklar aircraft might do 3 to 4 flights a day, so Paris, edinburgh, amsterdam, y'know, short hops. At the start of the day they require a "Daily" check first thing in the morning due to most of the work needed on them would have been done overnight. every subsequent flight (take off / landing) the plane requires a "transit" check, a sort alleviated daily check before it takes off again. A lot of the time they don't even have to refuel the plane 'cos the trips are so short and the engines are quite frugal on consumption. Theres minimal catering too, just need to load a few drinks, rolls and sarnies and they're good to go![]()
[TW]Fox;25344442 said:It must have been, right?
Except for the fact that Qatar do not operate a single plane long haul (Or infact at all?) that was built earlier than 2001.
But hey, you know it 'MUST' have been from the 70's. Right?
Engines have to be rebuilt/replaced after a certain amount of hours, air frames have recommended amount of cycles (takeoff/landing), commercial aeroplanes are maintained to a very high standard, especially ones used for international travel.
+1 What a bizarre post. I flown quite a bit now and I don't think I've been in a plane more than a few years old from any airline
