Right, so what is the correct way to turn this thing on?
Pressing the button on the front turns it on for like 2 seconds then it goes off....
"Xbox, On"
My console is not in that mode.
5.1 is going to be enabled with a patch.
You will have to select stereo for the time being.
Oh and when you get into Forza change the audio from TV to Home Theatre. (It just sounds better)
That's what I'm trying it doesn't turn the console on.
To be honest I had that the first time I tried. Ever since I first turned it off though, the controller has powered it on fine.
Are you set to fully off or quick boot in the power options?
Fully off.
How can I enable quick boot if I can't turn the console on?
Power brick LED is Orange.
Does the controller come on when you hold the xbox logo even if the console doesn't?
Yep. The controller guide light flashes.
