**The NEW Tomb Raider Benchmark Thread**
Status
Not open for further replies.
I can't believe that Titans are still top in the 1080P, as this is an AMD game and TressFX loves AMD :D
I know a 7970 is a great chip, but even so, its a big ask for them to top nvidia's flagship core :p
Hopefully those 290x's can reclaim first place once the custom coolers surface.
2700k@5ghz
7990@stock @1000/1500
13.11 Beta 9.4
1080p Benchmarks
Single 7990 core
7990
1440p Benchmarks
Single 7990 core
7990
Scaling %
1080p-95% Scaling 1>2 GPU
1440p-99% Scaling 1>2 GPU
Edit:
Just looked and Nvidia are top in all of them except for one (quad GPU's @ 1440P), which Catanonia is holding. Well done Cat for holding Team Red on your strong shoulders :p
I am off work tomorrow.:D
So is this going to be a full new build - case and everything?
I will be using a 900D
Some of the bits I will be getting out of the system with the watercooled RIVE (I hate that mobo, watercooling was a bad idea) like the CPU, RAM, PSU and SSDs etc. The mobo, rads and cards will be new.
1080p Run
2 x GTX 780 DCUIIOC SLI
Core:1320 Mem:1728
Driver: 331.82
I feel like something is artificially holding me back though, most of the bench was sat at exactly 119.9 fps.
Any ideas? pgi947 has a higher score than me but lower clocks :x
TombRaider_2013_11_24_20_41_19_304.png~original
1080p Run
Core:1320 Mem:1728
Driver: 331.82
Haven't got fps cap enabled in EVGA Precision? (if that's what you're using)
I was thinking of doing similar in a 900D. It's a cracking looking case. The Elysium has done me really well though. Will be sad to see it go.
1080p Run
Core:1320 Mem:1728
Driver: 331.82
Have you got Shadow Play enabled? Disable it via Geforce Experience via the power button. With it enabled it was knocking down my average from 214 to 170.
Double check your in game settings too, you might have something too high.
Also monitor clock speed while testing, its very possible one or both of your cards arent staying boosted at what you think they are. Before I put a custom bios on, my top (hotter) card was dropping the max boost speed by as much as 200mhz at times.
1080p Run
Core:1320 Mem:1728
Driver: 331.82
Something not quite right there in my opinion. I would expect at least another 20 fps on the average for those clocks. Is the CPU usage high with this?
Status
