** HIS MEGA DEALS & UNLOCKED R9 290's FOR YOUR CONVIENCE!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
This week is the week of great promotions, offers and deals, being of course Black Friday this week, so to get the ball rolling, check out these great HIS deals.
All these cards come with Battlefield 4 and some of them include the HIS Solar power torched and Toolkit, check under FREE items to be sure on what is FREE with the order, here are the deals:-
HIS Radeon R9 290 Pre-Flashed to R290X 4096MB GDDR5 PCI-Express Graphics Card with BattleField 4 PC Game Included @ £383.99 inc VAT
Pre-flashed by Overclockers UK Technicians using a voltage unlocked R290X BIOS unlocking the additional stream processors, giving a total of 2816 stream processors. Also voltage unlocked as well and with a full guarantee and warranty.
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:-
- Radeon R9 290 Pre-Flashed to R290X
- GPU: Hawaii Pro flashed to XT
- Stream Processors: 2816
- Core Speed: 1000MHz
- Memory Speed: 5000Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- Cooling: 2-Slot Blower Fan
- PCI-Express X16 lane required
- 750W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 2yr
Only £383.99 inc VAT.
ORDER NOW
HIS Radeon R9 280X iPower IceQ X2 Boost 3072MB GDDR5 PCI-Express Graphics Card with BattleField 4 PC Game Included @ £239.99 inc VAT
HIS R9 280X IceQ X² features iPower for more voltage; more overclocking, Boost Clock is faster, IceQ X² is Cooler & Quieter, user-friendly iTurbo, Long Lasting Design, OC equipment. iPower design allows the card to carry more voltage, expanding overclocking capability to a new level!
IceQ X² is one of the quietest coolers, making the card quieter than the reference cooler. The card is below 28dB when watching movies, surfing Facebook, working. The card remains quiet whether you are gaming, online socializing, entertaining or working.
Specification:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Hugely overclockable
- Core Clock Speed: 850MHz
- Boost Clock Speed: 1000MHz
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 6000MHz
- Power Connectors: 8-pin + 8-pin
- Display Outputs: 1x DVI + 2x Mini-DP + 1x HDMI
- Dimensions: 31.7x15.1x4.2 cm
- Power: 250W TDP
- 2yr Warranty
Only £239.99 inc VAT.
ORDER NOW
HIS Radeon R9 270X IceQ BOOST 2048MB GDDR5 PCI-Express Graphics Card with BattleField 4 PC Game Included (H270XQ2G2M) @ £155.99 inc VAT
The card has the latest Boost Clock technology, providing extra performance for the most demanding games and applications!
IceQ ensures effective cooling when there is another card in front blocking the fan inlet, such as in CrossFire setup. By expelling the hot air, IceQ removes all the heat generated by the GPU out of the computer chassis, prevents the hot air from accumulating inside and enhancing the overall stability. The more crowded the chassis, the greater will be the impact. The demonstration shows that the IceQ does outperform the 3rd party cooler in closed environment. Cool air is drawn from both sides of the fan and hot air is forced out of the computer case. This ensures effective cooling when there is another card in front blocking the fan inlet, such as in CrossFire setup. The demonstration shows that the IceQ does outperform the 3rd party cooler in closed environment. Cool air is drawn from both sides of the fan and hot air is forced out of the computer case. This ensures effective cooling when there is another card in front blocking the fan inlet, such as in CrossFire setup.
Black hole impeller ensures large amount of cool air is ready. It draws cool air from both sides of the fan even there is another card blocking the fan inlet on the front.
PCB might easily warped due to prolonged hanging on motherboard & casing, potentially causing cracks on BGA solder joints and resulting in malfunctioning of the card. The HIS special metal rib provides extra strength to the PCBs to avoid warpage, making the cards extra stable and durable. You can count on HIS cards to game hard for 24/7/365 for years!
Specification:-
- Core Clock Speed: 1000MHz
- Boost Clock Speed: 1050MHz
- Stream Processors: 1280
- Frame Buffer / Memory: 2GB GDDR5
- Memory Width / Speed: 256 bit / 5600MHz
- Power Connectors: 6-pin + 6-pin
- Power: 180W TDP
- 2yr Warranty
Only £155.99 inc VAT.
ORDER NOW
HIS Radeon R9 270X IceQ X2 Boost 2048MB GDDR5 PCI-Express Graphics Card with BattleField 4 PC Game Included @ £161.99 inc VAT
HIS R9 270X IceQ X² features Boost Clock is faster, IceQ X² is Cooler & Quieter, user-friendly iTurbo, Long Lasting Design, Boost Clock is faster. The card has the latest Boost Clock technology, providing extra performance for the most demanding games and applications!
IceQ X² is one of the quietest coolers, making the card quieter than the reference cooler. The card is below 28dB when watching movies, surfing Facebook, working. The card remains quiet whether you are gaming, online socializing, entertaining or working. The super large 2x 86mm dual axial fans draws massive amount of cool air to cool the GPU directly. The Q&C fan blade increases air velocity make cooling more efficiently while keeping noise level at minimum. The fan is extremely durable with a life span of up to 50,000 hours. The 5x 6mm wide heatpipes optimize cooling performance by removing heat from the core area. The extra large 60 x 62 mm copper heatsink provides a large area to dissipate heat efficiently. The card also carries memory and mosfet heat sinks to provide extra heat dissipation from these areas. The card also features fan control and monitoring, you are able to read fan speed & Asic temperature from iTurbo or other softwares.
Specification:-
- Power: 180W TDP
- 2yr Warranty
Only £161.99 inc VAT.
ORDER NOW
Great value for money when you consider BF4 cost nearly £40 to buy new from the shops.
We shall also later today launch a water-cooled version of the unlocked R9 290 as well. :)
What's the difference between the flashed HIS 290 and the flashed VTX 290? As far as i can tell all the 290 cards are using identical reference designs but with a different brand on the packaging (and different prices)... So would the cheapest 290 pretty much be the same as the most expensive 290?
Vtx one sold out.
His one includes BF4.
