Knocked £10 off for you, wait for website to update, they sell OK for us:-
NZXT KRAKEN X60 AIO Water Cooling Unit - 280mm @ £109.99 inc VAT
NZXT introduces the Kraken series, the first premium all-in-one water coolers for PC enthusiasts. The Kraken X60 is a high-end 280mm water cooling solution where ease of use meets functionality. Included are two NZXT FX-140 PWM fans, with capacity to install an additional 2 more fans in a push-pull configuration for unrivaled cooling performance. At the core of the cooler is a state-of-the-art pump attached to an all copper base. Bridging the radiator and pump is an extra-long 16” tubing and premium sleeved cables, easily installed into even in the largest chassis. We developed the Kraken series to be the best closed loop water coolers on the market, our customers should not settle for anything less.
• World's first all-in-one 280mm cooler with capacity to mount up to four 140mm fans
• High performance pump and copper block with interactive digital fan control
• Integrated HUE controlled LED pump cap
• Large tower support with extended 16" tubing and premium black sleeved cables for a clean look and improved airflow
• SATA power connector for easy installation and effortless cable management
• Completed sealed system backed by a 2 year warranty
• Material - Copper
• Pump Motor Speed: 2900 + 150 RPM
• Voltage: 12V
• Current 175 mA
• Fan Control: Interactive Digital Fan Control
• LED Color: Hue Controlled Color Changing Lights
• Fan Model: NZXT FX-140
• Dimension: 140 x 140 x 25 mm
• Speed: 800 - 2000 RPM + 10%
• Noise: 21 - 37dBA
• Voltage: 4.5 - 12V
• Air Flow : 54 - 98.3 CFM
• Air Pressure: 0.8 - 2.2 mm-H2O
• Connector: 4 Pin PWM
• Radiator Dimension: 138.4 x 27.0 x 312.5mm
• Material: Aluminum
• Tube Length: 400 mm
• Material: Rubber
Was [£119.99] Inc. VAT
Only £109.99 inc VAT.
ORDER NOW
Whereas can you get this kind of service?
