Permabanned
 - 15 Dec 2008
Thanks almighty. Unfortunately my 7970 is physically locked with a resistor - I've used the ghz edition bios which attempts to up volts, but then it crashes as without removing the resistor it is physically limitedIf I was brave enough I'd attempt to remove the resistor.
That's easy... You use the old Nvidia 780i reference board pencil mod trick.
Find the resister and with a 2B pencil put a few strokes between the 2 soldered ends of the resister as that will allow extra voltage to flow.
