Patch release for this but cant find notes anywhere ...
Try this > http://forums.overclockers.co.uk/showpost.php?p=25344188&postcount=891
I must admit I thought that patch came out a few days ago..
Yeah I used the Ati uninstall tool, rebooted and installed new drivers. My system is stock apart from the Cpu running at 4.3ghz so my setup is similar to yours.
Just out of curiosity, what version of windows are you running?
91 fps is too low? do you have bionic eyes? I've locked mine at 60fps as the game doesn't need any higher at all. Done the same for blops 2 as well.
Yes it did, there was a new one today and to be honest my game is running worse than before, its almost like I am in crossfire mode after disabling it, its a joke!
Nov. 26, 2013
Performance
◦Improved framerate performance when traversing moving platforms.
◦Improved latency for AMD graphics cards.
◦Improved performance issues caused by spamming.
◦Improved shader warming and level load performance.
Stability
◦Fixed crash in CODeSports play.
◦Fixed spawn crash for specific maps/modes.
◦Improved usability of broadcaster HUD.
◦Additional animations added for broadcaster mode.
◦Improved steam friends functionality.
◦Fixed smoke flickering and graphical corruption within blurred area of dual render scope.
◦Re-enabled fur and smoke DLLs from nVidia.
Additional Fixes
◦Fixed a variety of map specific spawn issues .
◦Fixed lobby migration closing the create a class screen.
◦Fixed not showing attachments and weapon camo for players while in private match lobby.
◦Fixed dog's extended kill not showing properly in final killcam.
◦Fixed loadouts appearing restricted if a restricted perk was selected in specialist strike package even though specialist wasn't equipped.
◦Fixed split screen UI issue that could potentially leave player in a bad state.
◦Fixed issue when selecting store from squads.
◦Fix to remember spectator team when switching to freecam in broadcaster mode.
◦Fixed issue with loading into specific maps with ghost mask equipped.
Can anyone explain to me why the hell this stutters like crazy on the main menu?![]()
I still get some lag at menu not bad stutter but def lag as bits move by....fine in game though though takes ages to load up with 2nd card turned on.
You got the crossfire issue sorted?
Its fine on one card now but still it kills my memory when crossfire is enabled, tries lots of settings in ccc but no luck so far, not sure what to change for the better tbh.
