All the reference cards are made by Sapphire regardless of brand, so quality wise should all be the same. XFX, HIS, VTX/PowerColor is popular right now because of their "chance" to unlock to a full 290x.Are the Sapphire versions of the 290 bad quality or something? I just ordered one and noticing that people don't seem to like them very much.
750w if your PSU is junk. those recommendations always seem to assume that, over stating it.Hi Marine, just looked at your PC specs, you have a R290X with a 625watt PSU, I thought the minimum specification for a 290X was 750watt. Reason i ask is i'm in the market for a new GPU with a £400 budget, but i have a Corsair TX650 PSU, could i run a 290 or a 290X with my PSU?
Have you maxed the power limit?I noticed my watercooled 290X is throttling core clock (according to GPU-Z) between 800-1000 Mhz, even though temps never go above 50C. Any idea why and how to stop it?
Not sure what you mean, how would I find that out? I have a Seasonic 650W PSU if that helps.Have you maxed the power limit?
Not sure what you mean, how would I find that out? I have a seasonic 650w psu if that helps.
Hmm, I'm still stock at the moment. Changing the power limit in CCC didn't seem to have any effect, though making it +20 in MSI Afterburner seems to have done the trick.
Actually, scratch that, I just saw I had it in quiet mode, I wondered what that switch did! I guess that solved my problem? Though looking at the benchmarks there hardly seems to be a difference? What's the optimal setup (I'm on water so no worries about noise).
Here's my Furmark in any case:
TBH the MSI afterburner limits are quite conservative if you are under water. Unless you got mad lucky with your chip, you wont get much better than 1250/1500 on +100mv without artefacts. If you are under water and use msi afterburner, all you need to worry about is whether the clock is stable, chip safety shouldnt be an issue since you can whack the power limit to 50% and core voltage to +100mv straight away and not even see a substantial rise in temps.
If you plan to clock this aggressively under water, you can start off with these max settings on voltage and Power limit and then set the core to 1150 and memory to 1500 right off the bat (i think someone mentioned that the memory is rated to work at 1500 with its stock voltage anyway, so even if you cant overvolt memory, you have plenty of headroom). After than try 1175, then 1200 and if artefacts start popping up, you can dial i back and fine tune it.
Pretty much did this till 1250, was stable in Valley but extended gaming sessions turned up an odd shadow glitch or some artefact every few hours. Dialled it back to 1233/1500 and now i haven't seen an artefact or glitch (haven't played bf4 though, wouldn't want to use that glitchy thing to test my card stability)
lol quiet mode is just a different fan profile since you are on water its irrelevant.
its probably power limit
Either overclock is safe. Save each profile and activate them manually if you need the extra grunt. If i wasnt so sure that half my GPU tweaking software would rebel if i switched afterburner on auto start, iw ould have my 1233/1500 24/7.
Going to flash to Asus bios soon (prob wait for a mantle supported benchmark tool or for mantle to be patched into some mainstream games) and then really abuse the 540mm of radiator thats cooling one CPU and one GPU.
