***The Vapers Lounge***
Status
Not open for further replies.
That screw at the top feels like the hulk did it up, it wont budge.
lol.
in that pic, its the 3rd ring down, the bottom shiny ring just above the main body
also adjust the silver centre pin up or down
but that third shiny one down needs complete removal to get it to work as I just tested...
if you undo it then it make the inside centre bit go further and further away from the battery and ends up looking a bit like it's unscrewed it doesn't seem like an adjuster at all?
the dial bit underneath the pin on the internal of the battery chamber, am I meant to be able to turn that with pliers or something?
Bah, mechanical mods confuse me already.
just received my nemesis clone finally and centre pin is meant to be telescopic and had a flat head on it but it doesn't push down AT ALL and the pin is bloody hard to attempt to undo. also none of my batteries seem to fit in it and there's a lot of wobble room, am I meant to tighten this pin down?
I would have thought so as my KFL and their dripper both have Huge clearance issues but wanted to check before I broke something as I've been waiting 6 weeks....
http://youtu.be/9tVGYcsS-hM
Watch that and see how he does it, if you take the battery tube off it should have a thumb screw to loosen so you can fit the atty flush. :)
Skip to 17 mins.
yerp pliers and a sock with a very small amount of pressure, too tight for girly computer fingers ;)
flat top panasonics 650's are a no go without beauty ring removal. ultrafire button tops seem to work. the button tops with the flat side pointing towards the floor and the button top facing the sky seems to be right xD
Just had my 2 nemesis clones arrive - posted 7th nov, arrived today, in case anyone is wondering about shipping times.
Just had the same issue figuring out how to build the nemesis for 18650 non kick mode..basically you need to remove to kick ring at the 'head'/atty end, then use the 2 bigger tubes and the switch end for 18650 mode
atty end has airflow control ring, then the head itself, then kick ring - i removed airflow control to get a good grip then unscrewed the kick ring.
Protip: screw your atty into the top ring, then tighten the adjustable centre-pin onto it before screwing the top ring onto the main tubes and finally the bottom cap. You'll get a perfectly flush atty every time and you won't ever screw the centre pin down with the atty and lose the connection.
Also, how diddy is it in 18350 mode! Doesn't last long at all though.
haha thanks, I have plenty more, that's my geeky silly one :)
I see why everyone gets magnets for this thing now, the spring switch isn't the nicest!
Update
There has been some behind the scene drama an several email exchanges between myself and VaperTrain, despite VT admitting they don't stock fakes and buy all their stock straight from the manufacturer's and not from third party resellers, AW confirmed the batteries I have are fake.
So if they want to take liable court action that is between them and AW now.
See AW's response:
http://www.cpfmarketplace.com/mp/sh...50-IMR18490-IMR18650-IMR26500-*Part-2*/page47
I have left VT with the above link and requested a refund. Let's see what they say now, otherwise I will proceed with a PP dispute.
Update
- VaperTrain have removed the batteries from their site as a matter of precaution.
- I've been offered an ex gratia refund including return postage once I return the batteries.
Whilst I'm happy I'll be getting a refund, don't go posting on other forums about them until I've got more info and if they will be chasing customers who ordered AW's from them.
If they don't or are a company who will try to buy my silence I will steam roll over them. Your, mine and general public safety is my number one priority. :)
Update
Good work fella - watching this closely.
Pretty much - but you'll find almost the exact same one on Amazon, at around that price, delivered.
I can get that literally 2 mins from where I live, I don't think Amazon do cheap delivery anymore... Think it has to be over £10 or the delivery costs now. It does not say accuracy anywhere but I assume it will go to 0.1 ohm? No idea...
Mmm got my vision spinner 1300mah today, 1.8 ohm coils, can dial it in NICE and get a balance of vapour and taste.... VV FTW....
Now I just need to get the stuff to build my own coils and I will be satisfied that I am getting the best possible vaping experience for the money!
Ekowool 2mm + Kanthal wire is the best for the protank mini right?
Status
