I mean the add on yeah for the high res textures...
or just install the game put it on max and bench?
Yes you need the add on, High Rez Textures.
i5 3570k @ 4.6
7990 @ 1140/1630
13.11 beta 9.2
Indeed a gain is a gain and also an interesting comparison seeing both setups running the same clocks.
Scoreboard updated.![]()
thought you'd like that lol. Hampshire huh, you might be seeing me in the future Kaap if you decide to sell your no longer needed cards lmao. Just down the road
4930k 5GHz
Amd r9 290 crossfire
Driver 13.11. 94
Dual GPU run under water
CPU 2600K @ 3.4 (stock) | GPUs 2x290 pro @ 947 / 1250 (or whatever AMD think "stock" is for these vague products)
Something is seriously wrong I think.
Finally I can participate in this thread
i5 [email protected]
R9 290x 1150/1500MHz
13.11 Beta 9.4
Windows 7 64-bit
I've just installed the Gelid Icy Vision Rev2 cooler last night, and decide to try overclocking it further. Eventually settled for the 1200/1570MHz (any higher than 1200MHz core clock I'd get artifacts and any higher than 1570MHz memory clock I'd get black screen- stupid Elpida memory...).And on the scoreboard.![]()
R9 290x 1200/1570MHz
13.11 Beta 9.4
Windows 7 64-bit
And with a little more overclocking
i7-2600@4800mhz
SLI 780ti boosting up to 1250
Driver 331.82 - WHQL
