- 19 Oct 2013
- Kent
Found this and just gonna give it ago
http://forum.hwbot.org/showthread.php?t=78490
Makes single threaded performance much better for us PD users
Now when I try to apply 4.8ghz, it isn't doing anything, I'm I doing anything wrong?
/QUOTE]
Do not panic Maths, I found the same. It has something to do with the driver version I think not working properly with overdrive. It is why I stopped messing and waited for Panos' guide.
If you have an asus board put the file on a USB stick, select in BIOS the EZ flash option.
Let us know how you get on bud, and draft a installation guide for us newbs![]()
I just had another go with CPU overdrive auto-tune in CCC, I gave it 1.48v Core and 1.7v Dram, let it run to 5000mhz.
Wow interesting cinebench boost there!
Cheers Panos!
That Stilt download is impressive, knocked 7 seconds of my SuperPI score for 2M (now 39s @4.4ghz) and added 260 points on CineBench to 701 points @4.4ghz, that is indeed impressive!
Just dropped £250 on this:
AMD Piledriver FX-8 Eight Core 8320 Black Edition
Asus M5A97 EVO R2.0 AMD 970
TeamGroup Vulcan (2x4GB) DDR3 PC3-19200C11 2400MHz
Does anyone know what sort of overclock I should be looking at on the stock cooler, and any recommendation of a decent after market cooler to go with this?
