- 13 Oct 2011
- Melbourne, Australia
[spec] 2011 spec
[/spec]
I have missed out fittings, tubing and coolant, but otherwise... this is what I would get...
Fittings + £50-£80
Tubing & coolant + £30
And the waterblocks + £180
Also you want SP120's not AF fans, SP's are better for radiators as they create static pressure.
I would also not bother with the 120mm Rad.. will be a nightmare to tube up and will provide little extra cooling performance.
[Channeling the spirit of Ethermaster] The PSU cables can be seen through the window and will be normally black/visible so look a bit messy.
It is also pretty tricky to mount a tube res in the 750D due to the OD and HDD cages.
