*** The Official Playstation 4 (PS4) Thread ***
Just spoke to Amazon and they are saying there are versions of BF3 that do not have the code for China Rising. If they are included it states it on the front of the box.
They advise just sending it back for a refund although I have asked them to refund the amount it costs to add the DLC as it is advertised as included on the site...
That's a bit cheeky what they're doing imo. Hope you get it sorted.
Hmm bit concerned about the HDMI issue regards to people having monitors rather than TVs - Im using a Dell 2407WFP with my PS3 and looking to use that for the time being for my PS4 - hoping I dont have handshake issues as I doubt its something I can get a firmware update for.
Guess thats forced my hand on getting a new TV then!
ps3ud0 :cool:
I thought under the blue PS4 logo there should be an orange bar saying that it included the DLC.
Might be an advertising screenshot rather than actual retail case.
I cant remember what my Xbox One cover looks like :confused:
It does on some but not all of them. Some have it some do not according to Amazon.
Just chatting with them now to see what they can do.
Your TV setup is incredibly infuriating.
TV not centred with the speakers? Check!
TV cabinet not centred with the TV or the speakers? Check!
PS3 and PS4 not centred on the TV unit? Check!
Ill bet the volume is on 19 too you monster! :p
Haha, I wasn't the only one then? *checks mouse mat is square to desk*
Well ive got mine, updated it downloaded Resogun and the free trial, putting my 365 days on and setting it all up. One problem so far is my Astros chat wont work even with an adapter i bought really hope its a adapter fault
is standby on the ps4 the same as ps3 when it was basically off but showing a red light?
Im not sure if off or standby is better as i want to use the psn features and I think it needs to be in standby to allow that?
Anybody help me with my ps4? I get audio but no picture on my monitor. Works on my mums hdtv but not my monitor. The xbox one works fine but i'm having ps4 hdmi problems.
P.S. it's not the bent pin thing.
Will need to see if it's possible to get an extension cable for the camera as the ps4 is in a rack behind me connected to a projector and the cable is too short, really wish they had used a standard usb connection. :(
