ULPS is disabled according to AB, and dropping doesn't seem to help (i'm testing at stock clocks after flash which are 1000/1500/1200mv, i'm going to switch over to bios 2 and confirm it does it at stock, then try a re-flash from the start just in case it's me being a tool.
Try that new bios i posted.
Tried it, still doesn't work.
I have the MSI HD7990. I'm stumped as to what is going on![]()
Give me your bios (master and slave from bios switch 2) and ill manually edit it.
 I'm starting to think this card is going to end up being returned as between the 1000 rpm fan speed difference at full whack, 10c temp difference and the constant throttling on one core when mining it's starting to annoy me. Shame as I'd half fancied another one and a pair of EK blocks for 2.8-3m/h but it seemingly can't even manage to run as it should with stock speeds/volts.
. I will try your bios on a later date.
