- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Looks cracking mate
You may get away with rotating the block 180 degrees of you want to keep it as is![]()
Thats what I plan, but will require draining and redoing the tubing. As the outlet and outlet holes are not central on the block, so one will be too long, other too short. Trying to determine the best way to drain it now, without losing too much fluid too.
