Permabanned
- 15 Sep 2010
Where did you get those green fan rings from please?
Just a guess, but I'd imagine those green rings would be a respray. It's a pretty simple and cheap task if you want your Corsair fans to be a colour other than Red White or Blue.
Spray on some primer and then a few coats of paint, done.
9-16c Cpu idle, 36c under load.
Fed up with space getting tighter and tighter in this case, will be remedied after crimbo though.
What RAM are you hiding under there?
I really need to get 540, soooo clean inside.
Is that Phantek literally lying on top of that 780?
