- 29 Aug 2010
- Cornwall
(I've mentioned this problem in the BF4 benchmark thread, but it understandably gets lost)
I recently bought a couple of Sapphire 290s (instantly flashed with the new BIOS from Sapphire's website).
I put them in my rig and moved the 7950CF into my other rig (see sig for details).
I did fresh driver installs on both machines using the DDU Uninstaller thingy from Safe Mode.
Installed the 9.4 beta drivers.
BF4 was getting around 70fps at 1080p on Ultra.
I then downloaded the 9.5 betas and did a clean install of them. But that failed, so I had to install the 9.4 betas and then install the 9.5s over them.
They seem ok.
Ran Heaven 4.0 on each. 7950CF gets around 1500 (using setting in Kaap's Heaven 4 thread), and the 290s get over 2100. This seems pretty reasonable for stock cards.
But BF4 runs at around 80fps on the 7950CF (but fluctuates a lot). On the 290s though I struggle to get 60fps solid.
One difference between the machines is that the 290 machine has 2 monitors attached (only game on 1) while the 7950 machine only has a single monitor.
I also ran the Metro 2033 benchmark on the 290s and the result was very low (can't remember it off the top of my head).
To compare, the 7950CF machine used to run a single GTX 670 and was getting around 70fps at the same setting that 7950CF is now running.
Both machines are running Win7 HP.
Any ideas why I get such poor performance?
Any ideas how I fix it?
Thanks.
They seem ok.
Thanks.
