Going to grab one of these starter kits and see how I get on. I have ZERO experience with linux at all) but it's mainly for XMBC duties so I guess it's pretty easy to install stuff and go from there.
http://cpc.farnell.com/jsp/level5/module.jsp?moduleId=cpc/678727.xml
You might like itGoing to grab one of these starter kits and see how I get on. I have ZERO experience with linux at all) but it's mainly for XMBC duties so I guess it's pretty easy to install stuff and go from there.
With regards to the SD card, I am probably going to upgrade that, infact I "may" have a bigger one lying about, will have to check, I also have an 8gb USB stick to get me started.
What will I need to update here? I want to get as much as I can out of a media centre, be able to add/remove/customise things, add things like iplayer, 4od, tv catchup services, want it to be a good allrounder media centre so I can watch films and possibly other things, this is the first time I have used XBMC so need to read up on what I can do.
Would OpenELEC be ok with this or is there a more preferred option?
Thanks all![]()
greatly appreciated, so you think run it from USB instead? do I still need the SD card or can that be used for maybe a little storage?
Thanks very much for your inputgreatly appreciated, so you think run it from USB instead? do I still need the SD card or can that be used for maybe a little storage?
I dont mind having a couple of services, really this is going to be used for films anyway
I guess I better get reading, already seen an app to control XMBC through the new tablet I will be getting![]()
I have an LG TV, not sure what model)If you're lucky and your TV supports it they actually have HDMI-CEC support built in, so on many TVs your existing remote can be made to work for controlling things (it doesn't work for me thoughI have an LG TV, not sure what model)
What happens when you press the 'Ok' button on your remote when in XMBC ?
I've used mine on about 4 or 5 different LG models now. Look at the options on the screen when you press Input. On one of the LG's I used (my newest one), I had to press the Green button on the LG remote to bring up the 'Enable Simplilink' screen. Once turned on, it works perfectly.
What model is your TV?
How new is the HDMI lead. Stab in the dark here, but do all leads support CEC? Or is it just 1.3/1.4 spec leads?
Does it have an ethernet port? Tried updating the TV? Or just manually looking online for an update?
I'd explore the HDMI cable first.
Any TV with Simplilink should work iirc
