Are you a Psychopath?
Man of Honour
17 Feb 2003
Chelmsford
Interesting feature. Lets' see who's the Psychopath of OcUK :D
Take the test and post:
http://www.channel4.com/programmes/psychopath-night
Psychopath Night is on Channel 4, Sat at 14th December at 9pm
YOUR
SCORE 42%
Though your conscience is in the right place you also have a pragmatic streak and generally aren’t afraid to do your own dirty work! You’re no shrinking violet - but no daredevil either. You generally have little trouble seeing things from another person’s perspective but, at the same time, are no pushover. ‘Everything in moderation – including moderation’ might sum up your approach to life.
Pretty spot on really.:cool:
67% apparently :O
edit: That was last night, today got 70%:
You can play hardball with the best of them! You know what you want and are not afraid to go for it – even if it means bending the rules occasionally and putting a few noses out of joint on the way. Nothing fazes you. You are decisive, self-confident and pretty much up for anything. You are a ‘means-to-an-end’ person. For you, it’s not necessarily a matter of right or wrong, but of what gets the job done. ‘Bring it on’ is your mantra, but to help those around you keep their heads, you should learn some tricks to help you temper your self-satisfying tendencies...
YOUR
SCORE 48%
Your
score 48%
45%, but the description seems to remind me a little of the forer effect (vague statements which could in theory apply to anybody).
So while it was accurate (for me anyway), it may be 'accurate' for everybody.
YOUR
SCORE 30%
You are warm and empathic with a heightened awareness of social responsibility and a strong sense of conscience. You like to carefully weigh up the pros and cons of a situation before you act and are generally averse to taking risks. You are very much a ‘people person’ and dislike conflict. ‘Do unto others…’ are your watchwords. But, although you avoid hurting others, those residing at the higher end of the psychopathic spectrum might not be as considerate, so stay vigilant to avoid being hurt unnecessarily.
48%
I do have massive problem seeing things from another person's perspective, though.
Your place on the psychopathic spectrum
Your
score 18%
36%
'Though your conscience is in the right place you also have a pragmatic streak and generally aren’t afraid to do your own dirty work! You’re no shrinking violet - but no daredevil either. You generally have little trouble seeing things from another person’s perspective but, at the same time, are no pushover. ‘Everything in moderation – including moderation’ might sum up your approach to life.'
61%
Your score 30%
