650w Power Supply sufficient?
Yep it'll be fine.
I'm running a 3770k, 8GB DDR3, R9 280X (basically a 7970 GHz edition) and LG Blu-Ray with a 600W Cooler Master PSU (also gold rated).
All fine here, except i recently had to return my Gigabyte R9 280x due to it's loud fans and annoying coil whine :rolleyes:.
This is where my money would go, i have just bought the 750w version. Jonnyguru gave the 650w 97% in his review. Quite a few reviews have mentioned the Corsair RM series using questionable quality caps and HardOCP failed the 750w altogether. All the EVGA units not built by Superflower (everything under 1000w) have recieved medicore reviews.
im running a 3770k and 7990 with a 650w psu no problems, ur rig with only 1 gpu to power would definitely not be a problem with a good 500-650w psu
