Core i7 "Haswell-E" Engineering Sample Pictured
Man of Honour
21 May 2012
Dalek flagship
Here's the first picture of Intel's next-generation Core i7 HEDT (high-end desktop) processor, codenamed "Haswell-E." Based on Intel's latest "Haswell" micro-architecture, the chip will be Intel's first HEDT processor to ship with eight cores, and the first client CPU to ship with next-generation DDR4 memory interface. In addition to IPC improvements over "Ivy Bridge" that come with "Haswell," the chip integrates a quad-channel DDR4 integrated memory controller, with native memory speeds of DDR4-2133 MHz; a PCI-Express gen 3.0 root complex with a total of 40 PCI-Express lanes, and yet the same DMI 2.0 (4 GB/s) chipset bus.
Built into the LGA2011-3 socket, "Haswell-E" will be incompatible with current LGA2011 motherboards, as the notches of the package will vary from LGA2011 "Ivy Bridge-E." Intel will introduce the new X99 Express chipset, featuring all 6 Gb/s SATA ports, integrated USB 3.0 controllers, and a PCI-Express gen 2.0 root complex for third-party onboard controllers. Interestingly, there's no mention of SATA-Express, which Intel's next-generation 9-series chipset for Core "Broadwell" platforms reportedly ships with; and X99 isn't looking too different from today's Z87 chipset. With engineering samples already out, it wouldn't surprise us if Intel launches "Haswell-E" along the sidelines of any of next year's big-three trade-shows (CES, CeBIT, and Computex).
http://www.techpowerup.com/195745/core-i7-haswell-e-engineering-sample-pictured.html
Where's the shut up and take my money gif when you need it
When is it out I want shiny new toys
First es chips are near always low clocks, iirc the 3960x es was clocked at 2.4 or 2.6ghz.
Looking forward to this, any idea what the high end memory dimms will come clocked at?
I hope they clock quite a bit higher than 3.0ghz though.
That's an engineering sample though, guessing retail will see 3.4ghz > 4.0ghz turbo on the 5960X and probably 3.3ghz > 3.9ghz on the 5930K.
Finally a worthy upgrade, I hope the 5930K is also an 8 core, and the 5820K is a 6 core.
If the 5930K is an 8core than I'm going 5930K + 16GB / 32GB DDR4. Plenty of time to save up lol.
Core i7 "Haswell-E" Engineering Sample Surfaces
"At launch Intel is understood to be intending to ship two versions of the chip: an “X” ,or extreme edition of the chip, as well as a “K” edition.":cool:
Full Story guru3d-
http://www.guru3d.com/news_story/core_i7_haswell_e_engineering_sample_surfaces.html
Reading that article it looks like the actual retail might ship with 3Ghz clock speed :(
Hmm, that doesn't bode well for power consumption / overclocking. A higher clocked 4770K would likely still be better for gaming..
