- 25 Apr 2010
- Ipswich
Project: Bad Kitty
So..I am just putting this up as a place holder for tomorrow as I am THAT excited!!!
This will be my first ever fully custom water-cooled rig and I am aiming for a black and orange theme!
So for now here is the list of parts I will be using gosh its going to be a HUGE delivery.
You will notice the lack of a PSU - It has been taken off the website (dont know why) My power supply = Be Quiet Power Zone 850W '80 Plus Bronze' Fully Modular Power Supply
YOUR BASKET
1 x OcUK Tech Labs H2O Custom R9 290X 4096MB GDDR5 Watercooled Graphics Card £499.99
1 x EK Water Blocks EK-FC R9-290X £89.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £263.99
1 x Avexir Core Extreme Orange Series 8GB (2x4GB) DDR3 PC3-22800C12 2933MHz Dual Channel Memory Kit (AVD3UH29331204G-2CIO) - Orange Light £169.99
1 x Gigabyte Z87X-OC Intel Z87 (Socket 1150) DDR3 ATX Motherboard £152.99
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £137.99
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black (CC-9011030-WW) £129.95
1 x OcUK Tech Lab - XSPC D5 Vario Pump & XSPC Acrylic Tank Reservoir Value Combo £99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £61.99
1 x EK Water Blocks EK-Supremacy - Nickel £52.99
1 x XSPC EX360 120mm Radiator - Black £47.99
1 x XSPC EX240 Multiport Radiator £44.99
1 x Akasa FC. SIX Channel Fan Controller - Brushed aluminium - AK-FC-08BK £27.98
1 x Alpenföhn 140mm Wing Boost 2 Plus PWM Fan £13.99
1 x NZXT CB-LED20-WT 24x White LED Sleeve - 2m £13.99
5 x Alpenföhn 120mm Wing Boost Pure Plus PWM - Black £9.95 (£49.75)
1 x Arctic Silver 5 Thermal Compound (3.5g) £8.99
1 x BitFenix Alchemy 24pin ATX extension 30cm - Orange £8.99
2 x Mayhems X1 Clear Premixed Watercooling Fluid 1L £7.99 (£15.98)
1 x BitFenix Alchemy 8pin PCI-E extension 45cm - Orange £6.98
1 x ModMyMachine Shoggy Sandwich V2 for your Watercooling Pump £6.98
6 x Monsoon 13/10mm (OD 1/2) Rotary 45° - Matte Black £6.95 (£41.70)
6 x Monsoon 13/10mm (OD 1/2) Rotary 90° - Matte Black £6.49 (£38.94)
1 x BitFenix Alchemy 6pin PCI-E extension 45cm - Orange £6.49
1 x BitFenix Alchemy 8pin EPS extension 45cm - Orange £5.99
2 x XSPC HighFlex Hose 7/16" ID, 5/8" OD, 15.9/11.1mm, 2m, Red/UV Orange £5.98 (£11.96)
10 x Monsoon 16/11mm (ID 7/16 OD 5/8) Free Center Compression Fitting - Matte Black £5.29 (£52.90)
1 x BitFenix Alchemy Internal USB Extension 30cm - sleeved orange/black £4.98
1 x BitFenix Alchemy Internal Audio Extension Adaptor 30cm - Orange £4.49
2 x BitFenix Alchemy 2pin I/O extension 30cm - Orange £3.95 (£7.90)
Total : £2,107.48 (includes shipping : £22.20).
OMG UPDATE - 18/12/13 - Parts have arrived
follow thread for more pictures.
YOUR BASKET
