- 7 Sep 2012
- Lancashire, England
Does anyone else here own a Gigabyte R9 280X Windforce OC card (rev 1)? I've gone through two of them so far and both have the same issues! I even tested my replacement in another PC and it didn't make any difference. The problems are:
* Coil whine (replacement card has a more pronounced squealing sound)
* Loud fans... I can manually lower the fan speed at the expense of having slightly higher temps, but the fan speeds reach 80% when left on auto which is unbearable!
* Fan sensors give out false readings... I've used OC Guru II, HWinfo, HWMonitor and GPU-Z and they all give out the same dodgy readings such as 84736378234RPM or nothing at all.
* Solder flux left on PCB... This annoys me as it gives the card a crap 'weathered' look and feels slightly sticky/tacky
I always thought Gigabyte were better than this. I'm going to email them and see if there's anything they can do about it... The least they can do is replace it with a rev 2 (which they must have released so soon for a reason!).
