Bundles? Its not a console.
You don't need extras either other than a case from eBay
So where is the cheapest place then?
So where is the cheapest place then?![]()
Second hand: eBay or members market
Brand new: Amazon, Google play store or hotukdeals
Also have invisible hand installed as a extension or plugin
Just picked up a 32gb nexus 7 for £199![]()
Where from? I fancy a 16GB but at that price it's worth paying the extra.
Hi all, picking up my 16gb Nexus 7 2nd Gen today.
As I want to set this thing up properly, can anyone recommend a definitive guide to "must do" things when your setting these up? I am a bit of a noob when it comes to android.
From what I gather, first things are to boot up/update to latest OS with any further updates, then root the device, is there any harm in rooting? I understand this invalidates your warranty? can you put it back to the way it was if you need to sort something in warranty (IE Rollback or recovery)?
But I know there is more to it than that. I am going to check out a few links on Google but wanted to see if there was a recommended guide someone had bookmarked thats more trusted than some of the results I am seeing.
Would appreciate any info![]()
I want to get rid of the anticipated bloatware that I am thinking is going to come with device, you would need to root to do this?
Never got to pick it up todaypickup after 5pm my ass
