Micro Hulk- My 1st build!
* small update *
Got myself the I7 4770k and AOC 144mhz monitor delivered this morning nice reduced prices due to black friday deals!
Not forgetting the haribo, thankyou OCUK!
Ok so still waiting in some bits but in the meantime im gunna do a dry fit. Going to flush out the rads, but is that all or does the cpu block etc also need a flush?
IM going to spray the fan rings a green colour seen as corsair don't have them. Is there a particular colour match i can do for my gigabyte motherboard?
Any help appreciated
there are a few places that have a really wide selection of colours but there was one near me a while ago that would let you try out on a bit of mdf first, somewhere like that'd be great or buy a few and try them out.
Couldn't hurt to drop them an email, maybe they could recommend a brand
So my attempt at spraying the fans was a shocker may have another go not sure.
But i did manage to mount the motherboard, cpu and cpu block for the moment:
So psu installed, i have a fair bit of room so will install my fan controller here.
You will notice my graphics card has a slight dip on the corner not sure why but i will try and find a solution.
P.S Sorry for the image quality
Yeah another green parvum build, glad to see :D Looking forwards to updates
Cheers bud, i bought the case a good 3 or so months back so i was watching yours with abit of envy lol while i waited for my money and parts to come in :D
Well i had another attempt at spraying the corsair fan rings and i got a much better result this time.
I will try and get some more updates this weekend hopefully
I managed to flush the rads out and mount them and the fans into the case and grabbed a couple of shots, also making an appearance is MICRO HULK
So this is pretty much it for the moment i cannot do much more until my cables, fittings and backplate have arrived.
Good news!
The magnificent rjkoneill has managed to get the fittings back into stock so they along with my ram and some other bits are on the way. I shall update when stuff is delivered and i have some time to get it all fitted.
