I'd like to build a new PC exclusively for gaming - priorities are it must be quiet and reasonably compact as it's going in the lounge. It's been several years since I last built a PC so I'm completely out of the loop spec-wise, but it seems you can now fit a reasonably performant gaming rig in a micro-atx form factor?
I've had a crack at a spec, but I'm not sure if it will all fit together, or if there are better parts for the cash, so suggestions welcome please. Budget isn't set in stone, but definitely no more than £1500 and the closer to £1000 the better.
YOUR BASKET
1 x EVGA GeForce GTX 780 ACX FTW 3072MB GDDR5 PCI-Express Graphics Card (03G-P4-3784-KR) £419.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £263.99
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £137.99
1 x Crucial Ballistix Sport 16GB (2x8GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (BLS2CP8G3D1609DS1S00CEU) £129.95
1 x Asus Z87 GRYPHON Intel Z87 (Socket 1150) DDR3 Micro ATX Motherboard £129.95
1 x Be Quiet Power Zone 750W '80 Plus Bronze' Fully Modular Power Supply £99.95
1 x BitFenix Phenom MATX Cube Case - Midnight Black £74.95
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02733) £67.99
Total : £1,338.85 (includes shipping : £11.75).
I'm definitely not interested in flashy lights or case windows, it needs to be fairly stealthy. I don't need large capacity storage (got NAS), mouse & keyboard (sorted) or a display (using the TV).
Questions:
1. Is the stock Intel cooler adequate if I'm not OCing?
2a. Will the GTX 780 fit in that case?
2b. Are there more suitable cases?
3a. Will there be room to fit a 2nd 780 at a later date?
3b. Does the PSU / mobo cover this?
4. Are there quieter options if I switch to a midi tower?
5. Where could I save some money?
Cheers.
YOUR BASKET
Questions:
Cheers.
Most of the SLI boards are more expensive as it is, so I don't think it's going to save anything there if I do want that option to upgrade.
