- 2 Apr 2006
The Philips 2W GU10's are currently 3 for £10 in Tesco.
Seriously dumb question (probably) but are these Philips a straight swap with the halogens? i.e. same transformer and fly lead?
I'm very interested to try these out as I've had no luck with LED's so far - they make both me and the missus feel sick.
Annoying glitch found with the varilight pro dimmer.
It is programmable, you can set the dimmest setting on it, to do this you turn the lights off dim the switch as much as it can, then turn it off and on 3 times, the lights then turn on go to full brightness and back down again to signal that the switch is in programmable mode, then if you leave it a few more seconds they flash and stuff to indicate that programming has finished.
So sometimes when you switch the lights on they do this on their own if you have switched them off when they are dimmed. It's getting very annoying![]()
The Philips 2W GU10's are currently 3 for £10 in Tesco.![]()
tempted to jump onto the LED bandwagon but few questions before I grab some.
I currently use philips energy 40watt bulbs they use 11watts, been using them around the house for years !
Would going LED give me the same kind of output and lower watts usage say these tescos philips 2w gu10s ?
These philips 2W GU10 pack of 3 for a tenner can I just buy these and plug these leds right in and enjoy 2watts of power over my current 11watts?
Damn, thanks, could have saved myself a few quid! Will check out the local tomorrow, need a couple more anyway
Yes, you would save 9w per lamp, but what fitting are the Philips energy lamps?
Average lamp at home spends 3 hours per day on, therefore 3x9W = 27Whrs saving per day = 0.027KWhrs. Energy cost at £0.12 / KWhr = £0.00324 saving per day. Initial outlay = £3.33 per lamp, so it will take you 1028 days (or 2 years and 10 months) to recoup your outlay before you start to reap the rewards.
If the lamp fittings are different you'll have to change much more than just the lamp, increasing your cost and lengthening your payback period. You'll also likely find that you need many more of the 2W GU10s than you currently have of the existing lamps to maintain the same level of light, therefore increasing your payback period even more. I would hazard a guess at it taking you 10-12 years to achieve break even...if the LED lamps last that long!
thanks great info, I guess I have the standard bulbs the ones from the pound stores. 60watt and 30watt ones, they kinda have 2 silver blobs on the end and 2 silver notches to slide into the groove the other end.
These leds look different with 2 pointy bits so doubt they will fit in mine.
Think with our philips were ok for now still![]()
John Lewis do these and seem to be the cheapest I can find (factoring in P&P).
Some seriously misleading info included in those lamps specs...why are Philips GU10 LED lamps having their output compared to a GLS lamp?
They need to be compared to the Halogen lamps they are intended to replace. A 20W Halogen GU10 has a centre candle power of about 200, but Philips 2W "equivalent" only achieves 120cd...and only delivers 105lm (about half as much light as from a 20W Halogen). I wouldn't touch them with a barge pole!
Wanting to replace all my kitchen spotlights with LEDs, I can't remember the exact type off hand, they aren't GU10, however they look the same but have more of a plug in connector... sorry for being so vague Can update once I get home.
Recommended places to buy?
Yes, the Philips are not great from a spec perspective, I did factor that in. However, in real life practical use, the brightness (for me) is just right compared to my existing halogens. The 4W LED Hut were just too bright. The reduced brightness also results in a softer light, and I think the Philips are also slightly warmer than the LED Hut at the same color temp.
