Out of the above brands, only the XFX and Powercolour has been confirmed to have chance to unlock.So im in Australia and can only get my hands on a select few, Powercolor, xfx, sapphire, asus, msi and gigabyte, whats the chances of any of these being flashed?
VTX and Powercolor, both the same GPU under different names, don't bother with XFX, crappy quality.So im in Australia and can only get my hands on a select few, Powercolor, xfx, sapphire, asus, msi and gigabyte, whats the chances of any of these being flashed?
But all the reference cards are made by Sapphire regardless of brandVTX and Powercolor, both the same GPU under different names, don't bother with XFX, crappy quality.
They are all exactly the same as Sapphire makes them for AMD then ships them out for individual branding (stickers). Obviously a few don't have lasered off shaders, but you get my point.
But all the reference cards are made by Sapphire regardless of brand![]()
They can't cut costs on the 290/290x because they are selling the same ones as everybody else.
Except you didn't quote the part which Gibbo said in the same post that at the moment all brand can only acquire the card as a whole which is pre-assembled by Sapphire.According to Gibbo, AMD sell GPU's to AIB's in different ways.
GPU chip
GPU chip + Ref- Board
GPU chip + Ref- Board + Memory IC's
GPU chip + Ref- Board + Memory IC's + Ref- Cooler.
They might only be selling the latter, but i wouldn't risk it given their history when VTX / Powercolor are available to him and probably cheaper.
I've fitted the Gelid Icy Vision Rev2 cooler onto my VTX pre-flashed to 290x last night, and while it did an excellent job in taming the GPU temp (75C max when overclocked to 1200MHz with voltage on 1412mV), the vrm temp can easily go out of considering hitting 100C+ if using higher than 1.350mV on the voltage. I think I would need to get a bigger sink for the vrm.
Yes it has enough 16 ramsink which is enough for the 4GB of vram. The vrm2 you just using the imagination with the leftover small sinks and thermal as well as the long thin heatsink for the vrm1. But if I were to do it again, I'd probably just uses these instead:I've got one on the christmas list. Did it come with enough heatsinks to cover all the chips?
What's the best tool to measure VRM temps?
No matter what I do I cannot see POST when booting from this card. I've tried various 290X bioses and I've tried it in 2 different rigs. I've never touched the 290 bios but even that doesn't show POST. Getting very frustrated by this. Can I please get some advice before being forced to return it.
Thanks.
@jonnyapps
What monitor/TV are you using. I know some TV/Monitors don't show the post due to the low resolution during post. My daughters been 1 and that's with a NV card in it. However the main TV in the living room does display it correctly, that's on my rig with a VTX3d 290x in it.
