Having just had a 780Ti killed by the fitting a waterblock, thought I would clarify some things.
I followed the EK instructions, but I have a feeling their thermal pad placement is wrong in the guide.
EK shows the following:
However, when looking at other cooling designs the R33/R22 modules are NOT actively cooled. As far as I can tell these are coils and do not require active cooling.
See:
http://www.riokou.co.uk/sin/780tiamp-8b.jpg
http://www.riokou.co.uk/sin/780tiamp-7b.jpg
Competing Waterblocks DO NOT cool the R33/R22 modules. When I removed the EK 780Ti FC waterblock I noticed that the pads did not even appear to have made contact with the R33/R22 modules. They were still stuck to the PCB whilst every other pad was stuck to the block, had appeared to have made contact and had some degree of recessed outline showing contact between part and block.
I am assuming the pads are non electrically conductive and won't cause issues even if placed in areas that they should not be. Or will it cause problems?
Would like a comment from EK if possible, why does the instruction manual show to cool these R33/R22 modules and secondly, why does the block appear to make no contact with them?
See:
