I had to do a double take as this was the first thing i saw.
Excuse me its been a hard day at the orifice.
EDIT
OFFICE*
EDIT
OFFICE*
Problem, reaction, solution...(applicable in many areas in life, too).![]()
.Indeed.
But if nVidia were proactive about it and made 6GB 384 bit bus cards as standard, saying:
"you need this VRAM because in the future when you may or may not adopt 4K and that may or may not exceed 3GB"
I think that would go down like a lead balloon. Especially with the associated cost increase.
Fair point. The answer to that is to produce both and give people an option though. You can never have too much, but you can have too little.
True. But they won't produce something if they don't think there's a big enough market for it. If they truly believed there was a market for it, they'd be straight in there vacuuming the profit.
Personally I would agree with their assumption of how things are. I think the market for 4K (i.e. VRAM chomping resolutions) is miniscule because quite simply the cards are not up to the job of pumping out acceptable frame rates outside of 3-way and above multi-GPU configs. So a miniscule market becomes non-existent (in market terms).
In the future this may change but we'll be a couple of generations on then so 2/3/4GB will most likely be redundant or close to anyway.
Don't forget 290Xs with full cover waterblocks don't do any better on the VRAM either.
One thing you can say in AMDs favour is @4K you don't need high VRAM clocks, a 512bit bus is far more useful. High VRAM clocks seem to make more of a difference when the fps is very high, this is not something that is going to happen @4K, there is going to be a lot more information in each frame which is where the 512bit bus will help more than high VRAM clockspeeds.
I don't know whether to laugh or cry about this comment...because it's so true in a way...+1
Good marketing though
Step 1 Mug your customers into buying 3gb cards "good for 4K"
Step 2 Customers buy 4K monitor
Step 3 Customers buy latest games available in 6 to 12 months time and find out that they can not max games out @4K
Step 4 NVidia steps forward with solution to your problem "buy out latest 8gb card problem solved"
Once 4K is common place these forums are going to be full of posts about 3gb or 4gb not being enough for 4K.
VRAM speed and Bus width, it all amount to the same thing, GigaFlops per second on the Memory threading speed.
With a 384Bit Bus the 780ti has about the same memory performance as the 290/X with its 1250Mhz and 512Bit Bus, the 290/X running the same 1750Mhz memory speed it will be churning out some 460 Gflop/s vs 325 on the 780ti, that will make a difference at any resolution.
But yes that difference will increase as the res goes up, but thats also because the 290/X has 64 Raster Units vs 48 on the 780TI.
The 290/X is predetermined to have very high performance, its held back at present with low component settings. there is more to be had out of it.
By comparison the 780TI has just about every little bit already squeezed out of it.
The 290/X is just more GPU tied up, anchored down. Can't wait to see it let loose.
That's all fine and well, but don't start a smear campaign on the opposition, and then recommend a 3gb card for 4K when it doesn't have enough vram, while going to great lengths to tarnish the Hawaii 4gb card.
How many 290/X's have you seen running @ 1750Mhz?
Already been thought this. you need to the thread before replying. the answer is in the thread![]()
Makes no sense but ok.
True, but
This is on Reference cards with Reference Coolers and no Memory overvolting.
There 7979 were running 1750, 1850 to 2000Mhz memory when they had decent coolers on them, they had memory overvolting.
AIB 290's should get the same and will clock well.
As for type and cost, AMD use exactly the same VRAM chips.
As i said, Reference cards with reference coolers, the VRAM chips aren't even cooled on the reference GPU's, actually its probably a good job there is no contact between the cooler and the Memory IC's, running as hot as those cards do the cooler would probably heat them up.
Better PCB's with better coolers and unlocked memory volting they will soon be running at 1750Mhz in the same way that any self respecting 7970 owner clocked their memory to that speed or more as soon as they installed it.
But There are Cheapskates, yes. just as you do with 780's and 7970's you make sure you know what your buying.![]()
Post #26 does not state anywhere that it is aimed at 1440 res people, it just says high res gaming.
That slide is just as bad as nvidia saying 3gb is enough for 4k.
.Lies. That slide was part of a package, I didn't include all the slides but seeing as you mentioned it...
There is no point going overboard with more than 2gb/256bit buses with the NVidia GK104 based cards. The GK104 chips are not as fast/powerful as their Tahiti counterparts and were intended for use as midrange cards originally. That's the real problem with GK104, the chips are underpowered.
