Permabanned
- 15 Dec 2008
VRAM speed and Bus width, it all amount to the same thing, GigaFlops per second on the Memory threading speed.
With a 384Bit Bus the 780ti has about the same memory performance as the 290/X with its 1250Mhz and 512Bit Bus, the 290/X running the same 1750Mhz memory speed it will be churning out some 460 Gflop/s vs 325 on the 780ti, that will make a difference at any resolution.
But yes that difference will increase as the res goes up, but thats also because the 290/X has 64 Raster Units vs 48 on the 780TI.
The 290/X is predetermined to have very high performance, its held back at present with low component settings. there is more to be had out of it.
By comparison the 780TI has just about every little bit already squeezed out of it.
The 290/X is just more GPU tied up, anchored down. Can't wait to see it let loose.
Memory bandwidth is not rated in flops
