Tweet is missing a comma... #justsaying
Loving it so far now that I am used to the controls/bugs etc. M4+Fireman's Axe = win
I did transfuse the wrong blood from a TFU member and I died... but at least we know how to do it now
For those interested - and apologies if it has been posted
1. Make sure you use a Blood Test Kit - one use only. Test yourself, so you know your bloody type, and test everyone else. Although some blood types work with others, I would suggest sticking to the same type
2. To obtain blood, equip a Blood Bag in your numbered inventory - bottom - and go up to someone who has the same blood type. Scroll to "Take blood"
3. Once done, this drops to the ground. Bug? Pick it up and combine with an IV Starter kit by dragging the latter onto the filled Blood Bag.
4. Drop this and give it to a friend
5. He/She then equips it into the numbered inventory and scrolls on you to "Give Blood Transfusion" (or something like that). You get the blood
Not sure about
A. If your blood type changes when you die or even log back in. Hopefully not
B. If they are clever enough to use the actual real-world blood combinations
C. If blood AIDS passes across during transfusions, i.e. if they're sick, you get sick
Good luck
Lots of new areas and all buildings are enterable
Not sure about
Good luck
Gonna buy this tonight.
Not read much into the standalone, but is the map exactly the same as the Mod? Or is there a lot of new stuff, watched a few streams last night and it looks amazing.
		 or ZAIDS? I know you can get a cold and need antibiotics but is there actually aids too?
		 I wonder if it was this reason. Who knows.
 I wonder if it was this reason. Who knows. a new era !
 a new era !
