Asked to put up a little summary of this case by someone who wanted it whilst at the shop.
Advantages:
- Great air flow, path of air travels straight through the primary hardware in the computer.
- Enough space to fit the Earth in. Case came with 3 fans, Ive taken one of the Corsair ones out and added 4 Antec fans that are more silent. As well as this I have the radiator for CPU liquid cooler, and still have bags of space. This is great because I plan to fully watercool this system in the future and this case will provide the space and easy management to do so.
- Looks awesome. Although has no LEDs built in, I like a little bit of colour so I've added both blue and red LEDs and it looks great, especially with the gigantic window that nearly covers the entirety of the side of the case.
- Very neat. With the PSU mounted at the back, along with DVD ROM, and with all of the cable tidies, all of the unsightly things can be shoved in the other chamber of the case, which is very very useful.
Disadvantages:
- Stock fans are VERY loud, however not a problem for me as I changed them anyway, but if you're considering keeping these fans, they're very loud.
- Only one dust filter? Very odd, the front fans get a nice magnetic dust filter, but the PSU and top fans are not given one, however again, not trouble as I managed to put a dust protector on them using 2 from my old case side by side.
Well, that's it, I can't think of any more disadvantages for this case, it's a great case and if you're thinking of buying, I would definitely recommend it!
Pictures:
System Specs:
Intel i7 3.9Ghz CPU
ASUS P8Z77-V LX2 Motherboard
MSI GeForce GTX 760 GPU
OCZ ZT Series 650W PSU
WD Black 1 TB Primary Hardrive
WD Red 2 TB Secondary Hardrive
12GB RAM
Corsair Carbide 540 Air Case
Case
Advantages:
Disadvantages:
Pictures:
System Specs:
Intel i7 3.9Ghz CPU
12GB RAM
Case
