Superflower product page - http://www.super-flower.com.tw/products_detail.php?class=2&sn=16&ID=93&lang==
OcUK product page - http://www.overclockers.co.uk/showproduct.php?prodid=CA-005-SF&groupid=701&catid=123&subcat=2057
Today I bring a quick look at a new PSU recently listed by OcUK from a very large PSU manufacturer that designs PSU's for themselves and also make PSU's for other well known companies. with a track record for making award winning power supplies.
About us.
Super Flower Computer Inc. was Established in 1991. We specialise in manufacturing and developing of power supplies, computer cases and related products. With our adherence to giving the best quality, we strive to make customers' needs the top priority and to expand our market. Our well-developed products include switching mode power supplies. PC cases, server cases and other accesories.
Jing Hua Co. Ltd. our new power supply plant was established in 2006.
With more than 10 years of design and manufacturing experience in the power supply industry, we offer a total solution and would like the opportunity to become your long-term partner.
If you can't find a suitable model from our catalogue our talented R&D team, can design a custom made power supply to meet your requirements. Our consistent efforts in higher density product development and new advances in technology promise to bring you products of the best quality at all times.
Packaging.
So the PSU comes in a white box.
Some of the key features such as the NIPPON capacitors the Platinum efficiency rating and the ECO thermal intelligence switch.
This graph shows the fan curve on rise and fall.
A multi language user guide is supplied also explaining the ECO thermal intelligence system.
Cables and accessories.
All the cables come in a pouch.
This is what comes in the pouch,
• One cable > 20+4pins MB power connector. 58cm between connectors.
• One cable > 8pins (4+4pins) EPS/ATX 12V connector. 68cm between connectors.
• One cable > 8pins EPS 12V connector. 68cm between connectors.
• One cable > 2 x SATA + 2 x 4pins Molex. 54cm to the first connector, 12cm between the rest.
• One cable > 3 x 4pins Molex + 1 x FDD. 54cm to the first connector, 12cm between the rest.
• Two cables > 4 x SATA. 54cm to the first connector, 12cm between the rest.
• One cable > 2 x 8pins (6+2pins) PCI express connector. 58cm between connectors.
• Four cables > 8pins (6+2pins) PCI express. 58cm between connectors.
A 2pin European plug is supplied but OcUK include a three pin UK kettle lead also.
Four thumb screws are supplied.
All the cables are modular including the ATX 24pin (20+4)
The braid is excellent and the wires are not visible.
All the individual wires are black which really helps.
The connector for the PSU end on all the cables have these jewel like connectors.
These are the rest of the braided cables, the SATA and Molex cables are all flat type which will help cable management around the HDD cages etc in modern PC cases.
PSU body.
The PSU has its own bag.
Stunning to look at in its all white design.
Power rocker switch and a 2-way switch to control the fan, this puts it in either ECO mode or Auto mode which is always spinning and usually at full speed..
All of the power on a single 12v rail.
The powder coating is lovely to look at.
All the connectors are well finished and give a firm tight feel when used.
The illumination of the connectors in daylight is plenty and certainly not dim.
But in the dark they really come to life. Only the ones receiving power illuminate, but some bleed seeps through from the others.
Fan noise.
My test system is the same as used here.
Test setup,
i7 [email protected].
Gigabyte X79-UP4.
Kingston HyperX Predator RAM@2133MHz.
Kingston HyperX 3K 240GB SSD's in RAID0.
Gigabyte R9 280X 2-way Crossfire.
Below are two videos.
The first is 5 minutes of BF4 and a further 5 minutes of Crysis3 gameplay while recording the fan in Eco mode, basically it doesn't spin up, I think I saw it spin up for a minute once last night then it went passive again after about 20 minutes of playing BF4 online.
The second is just a short video showing the fan noise starting of in Eco mode then into Auto mode then back to Eco mode.
Needless to say this PSU is effectively silent at all times. It never spun up to full RPM in Eco mode during my testing of it, during a 2 hour online gaming session I believe I caught it spinning maybe two times in total and that was only for less than a minute each occasion and that was at a slow RPM which again you can not hear.
Final thoughts.
Utterly gorgeous to look at and silent during operation this PSU is fantastic, the cables are nicely braided and of good length for big tower cases. The biggest overall impression is one of absolute silence, no fan noise, no coil whine, no nothing, if it was not for the fact that the PC is ON and the connectors are illuminated you wouldn't think it was working.
Pros.
• It's white.
• It is gorgeous.
• It is silent in Eco mode.
• The cables are well finished and have a nice braid.
• 5 year warranty.
Cons.
• Lol wut? ok it is £209.99, but this is a Platinum rated high quality 1KW PSU, I see Gold rated units for similar.
Thanks to OcUK for the PSU and Ethermaster for the banner.
