Been driving my Wraith Flash again but with the Renegade Shotgun.
That weapon is awesome to use and fun, it's the best weapon for the Flash now since the Fury got nerfed against infantry (it totally sucks, really does) which was unneeded.
Only problem is that there is a major problem with the Wraith Cloak, the cloak is bugged, if you not "your faction colour" then they can see you, sometimes it's just your head, but mostly it's your body and the only fix is to cloak and uncloak and for a Wraith Flash to keep doing that is life and death.
Did find something that made me smile is that am in the top for most Fury-H kills for Miller and in the World, planning on becoming number one for the Renegade which is within reach.
Pulled a Harasser few weeks ago after the great nerf, that thing is made of paper and as easy killed as a Flash is easy killed, don't think I could ever solo that anymore which is sad because I spent a lot of money buying stuff for my Harasser and spending a lot of certs.
Marauder is really bad now, it's not fun to use at all and totally crap against Infantry. The Devs have made it a AV weapon for use against Light Armour like Harassers, Flashes and ESF's and it does zero damage against everything else. I don't get it, why would you want to equip this when you can equip the Vulcan or Basilisk instead, I would had been happy if they reduced the damage but kept the splash range if they needed to change it.
Least the Pounders are good.
