Caporegime
- 13 May 2003
- Warwickshire
Hi all
I'm shortly going to install an extractor fan in our main bathroom and have a few questions:
1. Can I vent properly through an old water overflow pipe sticking out of the soffits? If so, any ideas how to properly connect the large vent pipe to the small gauge water pipe? The pipe is no longer used as it was connected to an old header tank, which is now redundant as we have a combi. Using this method will save me having to buy a tall ladder and a large circle saw, then having to drill another hole in the soffit.
This is the pipe (the left hand one, as the other one is taking the TV aerial into the loft
2. Any reason I can't wire it to the old now-disused 6mm^2 cable that the old electric shower used to run off? It obviously doesn't draw enough current to warrant the cable, but if I replace the fuse in the consumer unit from the shower with a lower rated one for an extractor fan, this should be OK right? I'll get a new ceiling switch for it.
I don't want it running off the lights because more often than not we don't actually need the fan running when we use the bathroom.
Many thanks.
):2. Any reason I can't wire it to the old now-disused 6mm^2 cable that the old electric shower used to run off? It obviously doesn't draw enough current to warrant the cable, but if I replace the fuse in the consumer unit from the shower with a lower rated one for an extractor fan, this should be OK right? I'll get a new ceiling switch for it.
Many thanks.
