** GET A FREE SUPERFLOWER 650W PSU - TAKE A LOOK INSIDE!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
By buying this 280X Bundle:- :D
Asus Radeon R9 280X DirectCUII TOP Crossfire Bundle - Includes 2x Graphics Cards with FREE 650W GOLD PSU @ £539.98 inc VAT
**24hr ONLY - GET a FREE Superflower 650W Golden Green HX PSU with this bundle!!**
The next generation Asus R9 280X DC2T graphics card has arrived, fitted with a 28nm GPU that packs 4.3bn transistors and is combined with 3GB GDDR5 Memory, it provides users with the speed for smoother gaming. Supporting full DirectX 11, AMD CrossFireX and AMD HD3D, the GPU includes an exclusive tweak utility which allows users to tune the performance of up to four graphics cards and check card status via an intuitive interface.
This GPU Tweak function links the GPU clock frequency to the voltage, so as you scale the GPU clock the voltage automatically follows; a useful tool for inexperienced Overclockers, It also enables users to select between 2D and 3D mode by providing the ability to change the respective clock speeds, voltages and fan speeds of either. Disabling the 2D mode also forces the faster 3D mode, stabilising overclocking and benchmarking results.
Embedded with GPU-Z to access accurate graphics card information, the card also contains a live update driver and BIOS benefiting users with the ability to keep their card in the best condition. Widget monitoring provides the choice to display the most needed information including a full widget, light widget or real time monitoring.
Furthermore, new PCI Express 3.0 delivers improved encoding and twice the performance of the previous PCI Express 2.0 and vision horizons can be expanded across six displays with AMD Eyefinity technology. This technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience.
Specification:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Hugely overclockable
- Core Clock Speed: 1070MHz
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 6400MHz
- Load / Idle Board Power: <300W / <3W
- Power Connectors: 8-pin + 6-pin
- Display Outputs: 2x DVI + 1x DP + 1x HDMI
- Power: 250W TDP
- 3yr Warranty
Was [£539.98] Inc. VAT
Only £539.98 inc VAT - FOR 24HR's WITH FREE 650W GOLD PSU!!
ORDER NOW
This is the PSU your getting FREE:-
SuperFlower Golden Green HX 650W "80 Plus Gold" Power Supply - Black @ £73.99 inc VAT
The Golden Green HX series are the perfect all rounder. They meet 80+ Gold Standards resulting in lower electricity usage, saving on the bills, hence the green. The Gold Rating means they are capable of powering pretty much any PC specification and the 14cm fan ensures the PSU stays cool whilst remaining quiet. One of our best value for money Gold Rated power supplies we sell.
Features:-
- Supports all Intel and AMD Dual Core and Quad core and its compatible Motherboards, ATX/BTX compliant.
- Supports Intel Core i7-980X / Core i7 / Core i5 / Core 2 Quad / Core 2 Duo &AMD Phenom II X6 / Phenom II X4 / Phenom II X3 / Athlon 64 X2series chip set.
- EPS 12V Ver2.92
- Patent black color connector, easy plug-in design, safe and firmly attached.
- Fit in with EuP(Energy-using Products) instructions / U.S.A Energy Star standards: energy consumption during shut off status less than 1W
- PCI-E power plugs are setup in a 6+2 configuration for the latest graphic cards and Compatible with every brand.
- Patent 14cm LED Low Noise Fan, Great air flow for exceptional heat dissipation.
- Passed 80 PLUS® Gold Certification, on 20% 50% 100% loading, with 91.64% 92.88% 90.99% Transform Efficiency.
- Full Range APFC, support 100V~250V.
- Patent high power and low consumption transformer / Patent dual voltage circuit with intelligence thermal control system (Patent applying for U.S.A, Taiwan, Mainland China and other countries)
- Solid state Capacitance is used for longer lasting and higher reliability.
- Extend Output Capacitance are used for higher stability and longer lasting.
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection
- Switches on/off test for more than 2000 times.
- Multiple safety certificates acquired.
- All series are made of RoSH unleaded green material.
Specification:-
- Real Power: 650W
- Transform Efficiency: on 20% 50% 100% loading, with 88.77% 92.82% 88.61% Transform Efficiency
- Intel Power Design Guide: EPS Ver. 2.92
- Outlook: Honeycomb ventilation panel, high efficiency air flow design
- Fan Size: 12cm Silent Blue LED Fan with temperature control
- Dimension: 145mm(L) x 150mm(W) x 86mm(H)
- Protection: OVP?OCP?OPP?SCP?UVP
- Safety Certificates: BSMI R33529 / CE / FCC / CUL / cTUVus / CB
- 1x 20+4-Pin ATX12V/EPS12V
- 1x 8-Pin EPS12V
- 1x 4+4-Pin ATX12V/EPS12V
- 4x 6+2-Pin-PCIe
- 8x SATA
- 4x 4-Pin-Molex
- Warranty: 5yr
Only £73.99 inc VAT.
ORDER NOW
This is an EPIC bundle for a really high-end PSU to be included free, it ends tomorrow, so DO NOT miss out. :)
A very good deal for those who need it.
Just make sure to have a good case with them, 2 cards blowing air into your case will be hot hot hot.
I wish they'd announce concrete stuff on mantle earlier so I could justify something like this for myself. But not right now.
Cheers, would have been awesome with some free games. Ordered 2 x 2 bundles so assume will get 2 x free PSU's?
Any chance these will go out today, just ordered about 10mins ago.
Thanks, should do nicely for mining. Wish I had gone for these earlier over my hot and noisy 290's for less money and power. Saying that deal has just come up today :)
I don't understand much about PSUs so can someone explain to me how a 650w PSU can handle SLI 280x? Surely you'd want something in the ball park of 850w if you're running SLI.
I bought and fitted this PSU last week, to take place of my Enermax NoiseTaker II..
An absolute beast of a PSU, quiet, and very much right on the money across all the rails..
Bonus, I saved £8 to what it is priced at now with 2 bags of haribo :)
