Whatever makes sense in your head, playa![]()
I can't believe i gave you those tips. Should've of known you were up to no good.
All I did was disable frame pacing.All I did was disable frame pacing.
I might try the rest of those tips later.
Have you tried comparing the scores ??Isn't Extreme Preset supposed to be running in 2560x1440P ? Then how come I can run it on my other PC in 1920x1080 at Extreme settings and get a positive valid 3dmark result !
Then comparing Extreme results make no sense at all !.
I'm going to plug my old 15" 1024x768 screen to the PC and see if I can run the Extreme test.
My first run of this test, just using stock clocks at the moment - as with the standard Fire Strike test I will rerun this with OC'ed CPU and GPU.
Score = 4597
CPU : i7-4770K @ 3.50 GHz (water)
GPU : GTX-780 @ 941 / 1502 (air)
http://www.3dmark.com/3dm/1994322
Been having my first attempt at overclocking and have managed to break 5k.
http://www.3dmark.com/3dm/1997553
i5 760 at 4.0Ghz
290X at 1,110 / 1350
Graphics: 5,619
Physics: 6,818
Combined: 2,415
Score: 5,079
Sorted a problem I had with my i5 760 not booting, just needed some extra volts and voila.
290@stock
[email protected]
290@975/1250
13.12 WHQL
SCORE
8136 with AMD Radeon R9 290(2x) and Intel Core i7-2700K Processor
Graphics Score 9101
Physics Score 13028
Combined Score 3451
http://www.3dmark.com/3dm/2002021
