Probably just me then. I am glad you can play in those cities but others have complained about dropping GPU usage within major cities... and even smaller ones. Now that almost every building is enterable and therefore contains loot, it does make it harder for systems to cope. I guess with high spec systems with CF/SLI, the drop in usage doesn't cause as much of an issue.
But you have to admit, GPU usage dropping when you need it most is bloomin' stupid? No?
What is your system, Marker, btw?
After last night's combatlog+kill on me, I have put DAYZ to one side. I almost put my fist through my screen lol
I5 @ 4.4, 7950 at standard with Dayz on an SSD.. Nothing major mate!
I do suppose the 4.4 will help though, if needed I can go over 5 with this chip and keep it cool enough with a low enough voltage..
