- 26 Dec 2013
- 404 Not Found
Morning guys.
I need some advise on getting the most out of cooling my PC with as little noise as possible.
Motherboard: Asus Z87-k
CPU: i5 - 4670K @ 4.2GHz
Memory: Kingston HyperX Genesis (2x4GB) 1600MHz
GPU: Powercolor HD5750
PSU: Akasa Cobra Power 650W Modular
Case: Xigmatek Alfar Midi Tower Case - Black/Orange
Soon to be upgrading the graphics card to something like a GTX 760.
I am using 4 x Xigmatek Orange Line 120mm as my system fans. 2 Running off the motherboard, and 2 running at a fixed 7V (Yellow arrows). My CPU cooler is a Prolimatech Panther CPU Cooler.
Is this fan layout ok, or is there anything I can do to improve? At full load my CPU temps are between 63-67 degrees. Would I benefit much from a push/pull setup on that cooler?
