- 16 Mar 2013
- Denmark
I bought this huge adjustable motorized computer desk 15 yrs ago. The desktop consisted of 3 laminated wooden plates which were set up to have a large CRT monitor on the right side. Since I have a small apartment I had it stashed at my brothers house the last couple of years but now he needed the space, so I decided to put a new hardwood desk on it.
Found a good sized desk plate in Acajou wood (a type of mahogany) at a hardware store. I gave it the recommended treatment of sandpaper and oiling as according to the instructions and it ended up looking as nice as I had hoped
The computer table's frame is amazingly sturdy and easy to work with and still shows no sign of wear. In 15 years all I had to do was change a broken link on a chain.
Put on the desk mount frame and took some measurements. Notice that the frame is asymmetrical. I'm planning to build a custom mount for my chassis (SilverStone FT02B-USB3.0) up under the desk in the gap on the left side of the frame.
Mounted the desk to the frame and installed the control system for the motors.
The basic table in it's lowest and highest positions
To be continued...
To be continued...
