1500 build spec?
22 Oct 2008
Lisburn
No need for windows OS or keyboard or monitor. Will be used for a lot of gaming so a high end graphics card would be ideal...780ti?
Needs :
SSD
Graphics card
6 core cpu or a good high end quadcore
psu
blu ray drive (optional)
motherboard with option for xfire/SLI
RAM
Cooler
Case
Are we able to get that within the 1500 budget?
nps, sort of creepy we picked the same gpu/mobo (almost)/ram? :p those bitfenix braided cables will look great also, i didn't add any because of budget concerns
ps: check out the Corsair 540 builds in the project logs section to get some idea how they look
That looks mighty familiar to a spec i did yesterday, as i remeber checking if the H110 would fit in top.. :)
I'd change the GPU for this one. Less money, just as good cooler and not RED! RED and GREEN don't go together. :eek:
YOUR BASKET
1 x EVGA GeForce GTX 780Ti Superclock ACX 3072MB GDDR5 PCI-Express Graphics Card (03G-P4-2884-KR) £569.99
Total : £579.59 (includes shipping : £8.00).
No, the Hydro wont fit in that case(350D).
It does:
http://www.corsair.com/en/pressrele...l-with-obsidian-series-350d-micro-atx-pc-case
If your not bothered spending that type of cash on a gpu just to have the fastest card on the planet currently then go with the 780ti builds being posted here, if however your a bit more shrewd and would either like to save a bit of cash or plow it elsewhere into the build, go for a non ref 290x, its almost as fast as the 780ti out of the box, so close you wont even notice the difference imho.
you can either pocket the dosh or plow it elsewhere into the build
I went over budget :( but I have gone crossfire and 2x these R9 280X are crazy fast :p, The only I can think that I personally would do is make a plate to cover the hot swap HDD bays as their ugly (still leaving a gap for some airflow) and find these RAM kits elsewhere:
Corsair Vengeance Pro Silver 8GB (2x4GB) DDR3 PC3-17000C9 2133MHz
Corsair Vengeance Pro Blue 8GB (2x4GB) DDR3 PC3-17000C9 2133MHz
I have used the RAM in the spec as a place holder :)
YOUR BASKET
2 x Gigabyte Radeon R9 280X Rev2.0 WindForce 3X OC 3072MB GDDR5 PCI-Express Graphics Card with Battlefield 4 PC Game £275.99 (£551.98)
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £245.99
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black (CC-9011030-WW) £129.95
1 x Be Quiet Power Zone 850W '80 Plus Bronze' Fully Modular Power Supply £119.99
1 x Gigabyte Z87X-D3H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £119.99
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler (CW-9060009-WW) £99.95
2 x Corsair Vengeance Pro Silver 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Memory Kit (CMY8GX3M2A1866C9) £79.99 (£159.98)
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £76.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £65.99
1 x Corsair SP120 Quiet Series High Pressure Low Noise - Dual Pack (CO-9050006-WW) £25.99
1 x Samsung SE-S208DB/TSBS External Slimline 8x DVD-RW (TV Connect) - Black £21.98
1 x Corsair AF120 Quiet Edition Low Noise High Airflow - Dual Pack (CO-9050002-WW) £19.99
1 x Corsair AF140 Quiet Series Low Noise High Airflow - Single Pack (CO-9050009-WW) £14.99
1 x Corsair AF120 Quiet Edition Low Noise High Airflow - Single Pack (CO-9050001-WW) £13.99
1 x BitFenix SATA Cable 30cm - sleeved blue/black £8.99
1 x BitFenix Alchemy 24pin ATX extension 30cm - Blue £8.99
2 x BitFenix Alchemy 8pin PCI-E extension 45cm - Blue £6.98 (£13.96)
2 x BitFenix Alchemy 6pin PCI-E extension 45cm - Blue £6.49 (£12.98)
1 x BitFenix Alchemy 8pin EPS extension 45cm - Blue £5.99
2 x BitFenix Alchemy Molex to 3pin x3 Fan adaptor 7V 20cm - Blue £4.99 (£9.98)
4 x BitFenix Alchemy 2pin I/O extension 30cm - Blue £3.95 (£15.80)
Total : £1,765.86 (includes shipping : £17.85).
